Jellyfin Integration
Hey Everyone,
I am releasing my new integration: Jellyfin.
This integration will expose a Media Player Entity which will show currently playing Image, Play Pause, Fast Forward, Rewind and Basic commands.
Integration support 2FA if you use a 3rd Party integration in your setup, Support http and https if you expose your Jellyfin externally.
Integration will connect to your Jellyfin Server and will identify all clients which are available with easy differentiation between the instances (Client Name) so you can add the one you want (or multiple).
Thank You and hope you enjoy this. More info in README.md file.
Hi MaSe, I have a problem using /controlling your Jellyfin integration (using a Ugreen Nas to store my Music data, no Home Assistant) on my Remote 3/2.8.3 . During set up of the integration I enter 192.168.1.244:8899 into the server URL… User name and password. It is all accepted and its installed/active. 1) should the server address include the address of my music directory (home/Philip Marsh/Music Jellyfin 2) When I start the activity should the Jellyfin player start/be visible on the TV screen. At the moment the TV screen is asking me for an input. Any help advice would be appreciated, Cheers.
Hey Sir, a few things:
You should see if you can join discord, easier to communicate there, as there are more users that can help you.
I apologize but i am having a hard time understanding the problem statement
I can only assume 192.168.1.244:8899 is your jellyfin server address? (i have no idea how your home network is set up).
What do you mean “on the tv screen” this confuses me, i am not sure i understand this statement.
The integration will connect to your Jellyfin server as long as the Jellyfin server and the remote are on the same network, then all the configuration is on your server itself, whatever / however you configure your server to work the remote simply send commands to the server and sessions, so all configuration will need to be done on your server, including where your music library live.
I am unsure i follow your description properly, i apologize. Also, i have 40 integrations and it is very hard for me to answer everyone and support everyone on a 1:1 setting, if you dont get answers here, join discord, there are many helpful folks there more then here.
New version up.
new update is live
