JBL MA7100HP AVR support/integration
Anybody knows if JBL AVR (MA7100HP) will be supported as integration? I know I can do it via home assistant using YAML or custom IP but obviously integrations are the simple route.
Maybe the ARCAM integration from @M.a.S.e will work? You can take a look at it. Link to Discord
Oh brilliant, I’ll give that a go. Thanks for sharing.
