I have SwitchBot curtain 3 in my home cinema to change my screen between 16:9 and 21:9 modes. I have the hub as well. Is there a way to add either the curtains (Bluetooth) or the hub (WiFi/cloud api) to the remote so I can control the curtains from the remote?
Maybe. The WiFi API works with json over TCP and this could be send with the Request Integration.
You could use a script in Home Assistant mapped to a button on the remote.
I don’t see a request integration, how do I add it?
