IR Hold Command
TLDR: Allow users to “hold” an IR command for a duration. (Both by holding down the button as well as an option in Activities)
I have a device that requires a very annoying sequence of “Hold Volume Up for 5 seconds, then press mute” command. Currently it is impossible to do this with the remote, and being able to do it as an activity would be the best thing ever.
You should raise this as a feature request here: Sign in to GitHub · GitHub
