at the moment I control my screen with my harmony setup. Now I want to learn the IR-Codes in my Remote3. During the learning process the the Dock says unknown command. Is there a way to get this screen working with remote 3?
You can find codes for the Euroscreen brand in the Global Caché database. You find tutorials here on how to import them. Just make sure to click on Send code set to download all codes
