IR command field
Does anyone know what should be entered in the IR command field? Please provide an example
command and command sequence can be used to add hold, repeat and repetition parameters for a command. It works will all commands that the remote entity supports like POWER_ON etc.. These commands also exist for Bluetooth and extenal (ip) remote entities. For ir remotes you can only add a repetition parameter.
