I’m trying to program the R3 with the IR commands for my Teufel soundbar (Cinebar 11). I’ve tried using both the learning function and the original remote control, as well as the command set from the Globalcache database. Neither of them works. When I try to learn the commands from the original remote control, I get a message saying that the device doesn’t support IR learning. Importing the codes from the GC DB works, and when I test them, the configurator also says the code test was OK, but nothing happens on the soundbar. So I’m starting to have my doubts about the Remote3, since the recurring network errors are really getting on my nerves. Does anyone have any advice for me?
Thanks in advance!
Best regards, Frank
