IR Codes of the Generic TV 1 most models for a Philips Android TV (SOLVED)
The IR codes of the Generic TV 1 most models for a Philips Android TV are not visible in edit mode and you cannot download them in the entity. They are also not part of the download of the IR datasets, because it is not a custom IR dataset.
How can I find out the used IR codes in these Generic IR datasets?
SOLVED:
I have learned the IR codes of the Generic TV 1 mosts model from the Remote 3 on my Harmony remote and after that I have learned these IR codes from my Harmony remote back on my Remote 3.
You can’t download them most likely due to licensing reasons.
In the Generic TV 1 most models for a Philips Android TV dataset there are IR Codes to select directly a specific source, INPUT_1 till INPUT_10. (INPUT_1 = HDMI 2, INPUT_3 = HDMI 3, INPUT_4 = HDMI 4 & INPUT_8 = HDMI 1)
On my original Philips remote I have only the button SOURCES, after which I can scroll to a specific source and select it by pressing ENTER. So I cannot learn this IR Code from the original Philips remote.
How can I find out the IR Codes of INPUT_1 till INPUT_10?
SOLVED:
HDMI 1 = INPUT_8 = 1;0xC6;12;0
HDMI 2 = INPUT_1 = 1;0xC4;12;0
HDMI 3 = INPUT_3 = 1;0xC8;12;0
HDMI 4 = INPUT_4 = 1;0xF9;12;0
Are the generic codes working? Why download?
If you have a Harmony or another universal remote which can learn then learn the codes there from generic Philips and then learn the codes from the other universal remote in the R3 again.
Thank you Ralf, great tip!
I have a Harmony and I will learn the IR codes on my Harmony remote.
And after that I will learn the IR codes back on my Remote 3 again.
