IR codes for LG TV, and others
I have the LG integration but it doesn’t specifically include HDMI 1, HDMI 2, etc. Only the “Input Hub” which isn’t helpful. My remote doesn’t have these direct inputs so I can’ learn their IRs. Where can I find IRs for LG tvs? And while I’m at it, what’s the best source for IR in general?
I did find the Global Cache site but I’m not an installer so my access is too limited.
The remote comes with a few pre-defined IR code sets including for LG TVs which worked for my LG G3.
You can request full access to the Globalcache database which worked without a problem for me.
Thx! I went straight for the LG integration (where the discrete inputs are missing) so after deleting that and creating an IR-based device it found the LG, and indeed it has the discrete inputs and it works with my TV.
Great. Btw, the LG Integration includes a command called input source which should have a drop down field with all the inputs and apps of the TV.
