[Integration] Philips Titan OS TV (Ambilight): local control, reliable power state, Ambilight modes
Hi everyone,
I’ve published a custom integration to control Philips TVs running Titan OS (2024+ models) from the Remote 3, directly over the local network (JointSpace API 6). There is no cloud service and no extra hub.
GitHub: GitHub - hugbig/uc-intg-philips-titanos: Philips Titan OS TVs (tested on a 2026 65OLED851) for Unfolded Circle Remote 3 · GitHub
Latest release: Release Philips Titan OS v1.1.0 · hugbig/uc-intg-philips-titanos · GitHub
What it does
  • Reliable power state. On Titan OS, the TV always reports “On”. The integration follows the TV’s change notifications the way the official Philips app does, so the state stays correct even when you use the Philips remote.
  • Power on/off with the Standby key, plus Wake-on-LAN from deep standby.
  • Ambilight page with every mode: video (AI, Standard, Sport, Cinema, Game), audio (Lumina, Disco, Rhythm), fixed colour, app, brightness/saturation, and an on/off toggle that restores your last mode.
  • Remote pages for controls and media, in English or French.
  • Every button is also a command for activities and macros (AMBI_GAME, AMBI_OFF, OPTIONS, POWER_TOGGLE…), with repeat/delay/hold.
  • Ambilight icons for activities and buttons are included in the repo.
I captured the official app’s requests with mitmproxy and checked each one on a real TV, so the integration only sends what the app sends.
What it doesn’t do (on purpose)
HDMI input selection, picture mode, volume display and a media player entity were tested and left out, because the TV doesn’t support them reliably. The README explains why.
Tested on
Philips 65OLED851, Remote 3. Other Titan OS models probably work too, and reports are very welcome (good or bad), especially for other models.
Install
Download the aarch64.tar.gz from the release, upload it in the Web Configurator (Integrations → add), then enter the TV’s IP and MAC and type the PIN shown on the TV.
Its driver id is philips_titanos_ambilight, so it can be installed alongside daCream87’s Titan OS integration (which inspired this one, thanks!) without replacing it.
Bugs and feature requests: GitHub issues. Questions: right here.
