Integration of JVC NZ800/NZ900 projector (IP control) - solution found
Had some difficulty integrating my JVC NZ800 into my remote. I used the JVC integration listed in the device database by Jack Powell. Though it was detecting the projector on my network, my projector was denying the connection. Apparently has something to do with how the JVC handles the password.
I found this very useful post online that helped me sort it out. Hope it will be of use to others.
https://support.habitech.co.uk/hc/en-us/articles/21543558466205-JVC-NZ800-900-series-control-issues
would this solution work for the JVC NZ700? Ive had the same issue
Hi, I use a 10-character password and it works fine.
are you using a nz700?
Hi, I use a NZ900.
