Integrating a Rotel Reciever
Any advice on how to add a Rotel Receiver as an integration? Also I have a Sony smart TV, model XR-65A90J that will not stay connected. Advice is appreciated.
On TV there is often an option that they stay connected. Sometimes they go to sleep and then network ist deactivated. Take a look at the settings of the TV.
@HarmonyFan Thank you! I will try this and report back.
I changed the settings in my TV. Unfortunately, this did not work. I need to figure out if I can set up an infrared option for powering on my Tv and if so can use this in addition to available Android TV integration?
You can use several integrations for a device and use all in an activity. Sony cxan be controlled by Android TV, BlueTooth, ADBTV and IR.
Question is the Sony really powered of by a plug? If yes it takes several minutes before in accepts IP input.
