Integra Control
R3 Backer hoping that my receiver and other devices can be controlled - I assume LG TV, Apple TV, Xbox Series X, Hue are common enough that they are no problem? How about Zidoo media player and Integra 8.4 AV receiver? Anyone controlling those yet?
Except Integra and Xbox all you devices can be controlled via ip integrations. The rest could be controlled through IR. If you can not find the codes in the database you can also import them for external sites like the Global Cache Control Tower database.
You can find a list of supported devices here Supported devices
There may be other custom integrations that are not listed there. Usually there are posted on Discord in the community projects channel.
@kennymc.c Please direct me to the LG integration. Thanks!
You find the link to the integration in the supported devices page in my first post
I’m controlling my Integra 8.9 with IR - using Global Cache PRONTO codes. You can use the Onkyo codes too as they are all the same chips.
