Instructions for learning another remote?
From reading other people’s posts, you can IR blast other devices and or learn other remotes, does anyone have instructions for any of these activities, first impressions are the device is fantastic, but basic instructions are missing on features and functionality.
If you can get the IR codes from the manufacturer you can add then that way which is probably the best approach. I still dont know how to do this though. Its in the web gui if you want to look.
Found it, thank you!
