Input selection problem
Hello.
I am at a deadpoint now. If I connect every device to the NAD AVR I can change the input without a hassle. Only my apple tv get a black screen because of the connection with the AVR.
If I connect everything to the Samsung TV (Frame) i cannot select an input on the TV with the remote. In the Samsung integration the Hdmi 1 doesn’t work. Only HDMI works as a toggle but that is not convenient with changing inputs.
Does anyone have a solution?
Michel
I have 2 rooms where I can not control everything perfectly until I actived and configured CEC on all devices. Advantages are it works with the original remote, Harmony remotes and also Unfolded remotes.
If you get your configuration so that it works with only the Apple TV remote it willwork with R2/R3. In case of use with CEC only the main device (Apple TV) must be in the start/end sequences.
The problem is not the Remote, but Apple TV behaving weirdly in combination with NAD T778. I have resetted everything and also went back to factory reset in the Apple TV. Now it works again. I hope it will stay this way and I will keep the Apple TV now constantly on.
