Hi, regarding the integration “HTTP Requests, WoL & Text via TCP” (Configure custom entities):
Is there a limit of 7 entities? Because if I try to add an 8th one, I get an error.
See the example—if I leave out the first or the last entity, it works without any issues.
Example:
Entity SAT Wohn Plug:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.252/cm?cmnd=Power off
‘On’:
Type: get
Parameter: http://192.168.1.252/cm?cmnd=Power on
Simple Commands: {}
Entity SAT Wohn DeepSleep:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.71/web/powerstate?newstate=1
‘On’:
Type: get
Simple Commands: {}
Entity TV BWL Entity:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.172:36002/CMD2
‘On’:
Type: get
Parameter: http://192.168.1.172:36002/CMD1
Simple Commands: {}
Entity Beamer BWL:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.172:36002/CMD4
‘On’:
Type: get
Parameter: http://192.168.1.172:36002/CMD3
Simple Commands: {}
Entity SAT Buero Plug:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.250/cm?cmnd=Power off
‘On’:
Type: get
Parameter: http://192.168.1.250/cm?cmnd=Power on
Simple Commands: {}
Entity SAT Buero DeepSleep:
Features:
‘Off’:
Type: get
Parameter: http://192.168.1.70/web/powerstate?newstate=1
‘On’:
Type: get
Simple Commands: {}
Features:
‘Off’:
Type: get
‘On’:
Type: get
Simple Commands: {}
Entity BluRay:
Features:
‘Off’:
Type: get
‘On’:
Type: wol
Parameter: 68:27:37:38:7F:17
Simple Commands: {}
