HTTP connection no https?
Hi All,
I don’t have a actual remote yet but was checking out the virtual machine core simulator and to my suprise I did not find a option to import a certificate and use https?
Is this option already there or is it coming?
Looking forward to hearing from you.
Kr,
NJk
HTTPS is supported but it’s only using a self signed cert.
That makes sense, @kennymc.c thank you for the prompt reply!
