I see that for Remote3 this integration Integration Manager is available, but how can I load this integration on the Remote2? The integration page on the Remote2 does not has a custom integration, but only the fixed list of intergrations from the unfolded website and I am not able to add custom or external integrations.
First of all you should activate Beta-Channel on the web-ui.
Settings –> Generally –> Software update
Here set all switches to on. Now you get the latest software. Now let the download and installation do their job.
Meanwhile you can download the integration. Click on the link inside the thread for the Integration manager. At github page click on “latest” (screen right side) .
Remote2 tells me that there is no new beta software available.
Ahh, but after a restart of the Remote2, now version 2.6.12 is available for the Remote2 and have I now the same firmware on the Remote2 as on the Remote3
