Manufacturer: LG
I imported the LG TV Generic IR Codes in a new Entity. I can use the functions in Automation. But how can I import the pre-defined UI elements and the Keys?
I tried this tutorial: https://support.unfoldedcircle.com/hc/en-us/articles/13216044176156-How-to-add-an-infrared-IR-remote
But how to do this step on Remote 3?
”Don’t forget to add the remote entity to the UI under the User interface menu in your profile." ?
Thanks for your support in advance
Micha
