I for example use MusicCast from Yamaha and it has a nice media library function to select radio stations for example. It works great in Home Assistant but I will not be available in any way for the RemoteTwo. This means that I can see the cover art and have volume control as well as play/pause, but I can’t switch radio stations because it’s not coming over from HA. As it looks It is the same with Plex library. Any thoughts?
It’s coming: Media browsing, including playlist, albums, etc.
Do you still want that if they are integrating Roon? They have limited resource and as roon can stream to your Yamaha (including radio) why not use that?
Just a thought.
If im honest im concerned at the workload coming their way and if they can deliver on so many unique requests.
