How can I customize the user interface and the key mappings and of devices that are integrated via integrations?
Dear all,
How can I customize the user interface and the key mappings of devices that are integrated via integrations? I don’t mean in the activities, but in the device itself - which are used and shown for corrections. With infrared entities, this works quite simply - I can’t find it for devices integrated via integrations. Where do I look?
Thanks for help,
Helmut
You can only for certain devices which offer a so called remote entity.
I do not know which because I only use activities.
Ral
I want to use this to get access to all buttons / functions of the specific device. On Activities I configured only function are often used during watching. But for special configuration I use the “Correction function” all buttons of a device.
I am struggling with the same issue. I am using the Nvidia Shield integration and am trying to use custom icons for the apps provided with the integration (e.g., netflx). Unlike IR entities, which provide a full list of commands to which icons can be selected, the Nvidia integration does not provide this.
Shield Apps with icon on display works in activities. Perhaps after one of the next updates if Android TV integration got the remote entity.
See here:Show us your custom pages and icons - #19 by HarmonyFan
