I see that the Homey pro is also supported, I am curious about this integration and that in two directions because I already see that it will be possible to start a flow on the Homey from the remote. So no real questions yet but very curious
Almost, almost we can test. Another way of communications is using mqtt, then you can do anything you want between remote and homey. A bit more difficult to start with, but if you have the base and know the way how to send commands it is rock solid and very fast.
Hey Marco,
can you give me little tutorial on how to realise the connection via MQTT?
That would be great!
I have never tried this in combination of the remote two.
I only use the unfolded app form the h9mey app store for integration and that works fine.
For mqtt there are forum threaths on Homey comm7nity forum.
Thank you for your fast response!
Unfortunately, the integration does not work for me anymore. I can’t discover any homey via the remote two. From one to another, I just couldn’t connect them.
Maybe I will find a solution in the community forums of homey.
Are you sure that both are on the same wifi ssid and if possible during setup connected to the same Access point? Ubiquito and Mesh WiFi solutions tend to filter multicast traffic.
I use a Homey 2023 and it works fine. I do user mqtt as well with the Homey, but not in combination with Remote.
Thank you for your suggestions, but it worked fine for about half a year and then it suddenly stopped. I tried reconnecting, backups und factory reset. Nothing works.
I will see, if there is a proper solution and tutorial for the connection via MQTT ![]()
I have just published the newest Homey integration. Is has quite some fixes, and now uses the latest UC API version. It is tested and works great on R2 and R3. When Homey certified the code it will be live. If you can’t wait or want to be one of the first, then use this link Unfolded Circle | Homey to install it now, ahead of certification.
there are a couple things that i think could be the issue.
It either is allready connected (then it won’t show when adding a new integration but should show in integrations), It honestly can’t discover. this could be because the devices are not connected to the same network for instance.
Could you try the latest version of the app? and see if that fixes things for you?
Thank you for response.
I have done it via direct IP with the API. The support has send me a tutorial on how to do so. The problem with my network is, that mDNS is not working properly.
Professional WiFi by any chance? Some vendors do the weirdest stuff with multicast packets. Or even change the content of mDNS packets. I’m sure there is a fix though.
Thank you very much for your effort - but as I said, I did it via direct IP, which is way more stable, I think.
My network consists only of AVM parts in a mesh cluster.
