I’m using the Remote 3 for 2 weeks now. I also installed the Homey integration. I can start flows now, so that works. But is it also possible to operate my Homey attached lights and other devices from the remote?
As far aa I know, you should be able to switch on/off devices that have an on/off capability (like lights and smart plugs). Specifically for lights I understand that dimming is also supported.
I am controlling my Homey connected smart plugs with this integration.
I already found it. The names of the entities looked a bit strange, but now I see these are my devices ![]()
