I have some problems with the Homey Integration on my Remote Two
- To “Create” a Trigger, i have to use normal Flows, advanced Flows did not work
- It took a while to update the Homey Integration on my Remote till the new Triggers where shown
- I can add the new Homey Triggers as Entitys into my Activities, but then i can’t do anything with it…
My goal is to trigger a flow on my Homey with the ON/OFF Sequence of my activitie. Could someone give me a hint, what the next step should be?
Thank’s ![]()
