Home hubs control
The website describes controlling home hubs. Can the remote control a Harmony hub? If not which hubs are comparable?
There is a Harmony Hub integration but it has to be run on a separate device via Docker as the developer hasn’t released a version that can be uploaded to the remote
You can find other compatible devices or systems here: Supported devices
I think with home hubs it is more meant controlling home assistant, homey or similar.
Yes but the integrations include hubs like Hue and Bond too …..
