Home assistant integrations (solved)
I see that there are two different integrations for home assistant.
One from unfolded and one custom integration.
Can someone tell me what are the differents and which one is better?
If I’m not mistaken, the official (UC) integration is loaded into the remote and allows the R2/3 to see and control entities from Home Assistant.
The community integration is loaded into Home Assistant and allows HA to trigger activities on the remote.
I understand, thank you
