Home Assistant: how to trigger scripts and automatons
did anyone find a way to trigger scripts and automations from the Remote3?
They are no entities and thus not appearing in the Remote3
You have to share them with R3, then they will pop up​:wink:
I made helper buttons and switches. Shared those with the remote and use these as triggers for the automations.
If that’s what you mean..
Tnx, that’s exactly what I needed!
