Home Assistant and HACS
I added a custom integration to Home Assistant via HACS and it appears in Home Assistant. However, it doesn’t appear as an entity to be added in my Home Assistant integration for my R3. I deleted and reinstalled the Home Assistant integration and it still isn’t there. Does anyone have any thoughts or suggestions?
What is this integration and what are you trying to expose to the remote?
It’s a special Samsung tv integration. All the other ones have issues and the source selection (e.g., HDMI 1 etc) do not work. This one was done two weeks ago and apparently fixes those issues.
I tried to add the tar file directly as a custom integration but it wouldn’t work. But I was able to add it to Home Assistant via HAVS.
