Hide a page on Customise your remote
Hello, I wonder if someone can help, thanks?
On my UC3 Web configurator, Customise your remote screen, I have two pages, Living Room with activities and Remotes which has all the entities where I’ve tried to replicate all the original remote buttons.
While I was away my wife managed to scroll the UC3 away from the Living Room screen to the Remotes screen which caused confusion. To stop that happeng again I could just delete the Remotes screen but does anyone know if it’s possible to hide it on the UC3 screen?
Thanks, Steve.
Just a thought that isn’t quite hiding it. You could create a separate user profile with a single page with just the living room activities in it, and make that the everyday usage profile. You could then switch back to your original profile when you want access to both pages with the activities and remotes.
Well that’s so obvious that I’m embarrassed I didn’t think of it!
Thanks very much, that’s great. :grinning_face:
Can you quickly & easily change user profiles? Also are you able to just ‘copy across’ existing pages from one user profile to another?
You can simply change to anther user profile by opening the settings or swipe from the top
And can you copy existing pages between profiles or would I need to set the new profile up from scratch?
I’m not aware of any way to copy home pages from one profile to another. You’d need to create new home pages in the new profile with the UI that you wanted for that profile. Activities etc are not profile dependent so you won’t need to recreate those, you’d just need to create new home pages for the profile and link those to the required existing activities etc.
