Hidden wifi SSID supported?
Cheers,
has anyone tried to use a hidden wifi SSID for the connection? My system isn’t logging any associations when trying to set up the remote, and I’m not sure if that’s the problem or we’re just stumbling over something else here.
Well, judging from the log files, it really doesn’t consider trying to connect to a hidden network:
2023-09-17 20:27:20.710823 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:27:08.909511 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:26:57.117830 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:26:44.947255 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:26:33.154422 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:26:21.337759 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:26:09.414764 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:25:57.320920 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SCAN-FAILED ret=-11
2023-09-17 20:25:54.649411 +00:00	wifi	INFO	wlan0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
2023-09-17 20:25:54.645766 +00:00	wifi	INFO	wlan0: CTRL-EVENT-CONNECTED - Connection to a6:a2:f4:c2:e3:8a completed [id=0 id_str=]
2023-09-17 20:25:54.641567 +00:00	wifi	INFO	wlan0: Associated with a6:a2:f4:c2:e3:8a
(the association at 20:25:54 is the non-hidden network connect, the above is hammering the connection attempts)
