I had to replace a failed 1st Gen NVIDIA Shield with a new Pro model and deleted the integration to start again… that was probably a mistake. ![]()
I’ve added in the new integration and mapped the cursor buttons, but I keep getting a red ‘Conflict’ error bar. Yes, I have installed the Android TV Remote Service from the Play store. Was that a second mistake? Seems there was already an OEM version in there that I didn’t now about.
Anyway, some help would be appreciated. Thanks in advance!
