the word blaster is a bit of a mouthful ![]()
While not the best solution but this works for me, if you have two docks try placing one on its side with the charging port facing the devices. I did this and found no need for blasters at all seems all those new higher power IR LEDs are pointing at the ceiling and not running anywhere ear full efficiency!
the round tops of the blasters are pointing to the dac (and all other devices
this ok now until i find a better solution ![]()
Hello,
one possible and simple solution, if the weak IR-power of the dock is the reason for the short range:
https://unfolded.community/t/deutsches-forum/638/773?u=tiki
Well, it requires the courage to open the dock and a minimum of soldering skills…
Cheers, tiki
Thank you makes a great fallback plan if my replacement blaster fails to work!
Bill
