Just reaching out to see if anyone else having a similar issue.
Although there are some comments regarding the remote being slow to respond after going to sleep. When I pick up the remote and turn on a an activity, the relevant power on sequence works but when the new page is shown, any actions programmed on screen work fine but no hard buttons work. This even applies to a duplicated ir, say play/pause which works on screen but not with the hard buttons. When this problem occurs all hard buttons are affected. The only way to rectify this is to do a reboot whereupon everything will work.
If anyone else has seen this issue, have you discovered what may be causing this?
You can contribute to this ticket with these informations:
What kind of entities and integrations are used within the activity
Button mappings of the activity
If the activity is within an activity group
If multiple activities are running
Log information
Settings: Development/Logs
Download logs from: Core service, User interface app, and optionally the integrations you are using in the activity.
Priority: DEBUG
If the event to observe didn’t happen right before downloading the log file:
increase the number of log entries to 1000
optionally set a timeframe
I have just posted a log file. As mentioned in my post, it seems that this issue has been fixed on home assistant integrations : I don’t have any loss of physical buttons commands, except when the remote wakes from sleep where it needs a delay to reconnect.
This apart, the AppleTV integration (and probably the shield’s one) still have the same problem. A soft reboot is necessary to make it work again.
