Hi everyone! I’m excited to share my FYTA plant sensor integration for UC Remote that I’ve been working on. You can find the code at GitHub.
What’s Working
Full Python implementation
Authentication with FYTA API
Temperature and moisture sensor data display
Easy setup through UC Remote interface
Works with the default “Günther” plant for testing
Known Limitations
Needs reinstallation after remote reboot
No periodic updates yet (one-time data fetch at setup)
Basic error handling
UI can freeze during entity setup (temporary workaround: refresh the page)
Looking for Help!
I’d love to get your feedback and contributions to make this integration better. Specifically looking for help with:
Adding periodic data updates
Fixing the reboot persistence issue
Improving error handling
General code improvements
The integration is fully functional but in early stages, so any testing and feedback would be incredibly valuable. If you have FYTA sensors, please give it a try and let me know how it works for you!
Quick Start
I’ve included detailed setup instructions in the README, including a pre-compiled version you can try right away. You’ll need UC Remote with beta firmware 2.3.0.
Feel free to open issues, submit PRs, or reach out with questions. Let’s make this integration awesome together! ![]()
