Full size clickable button without having to open a pop up first
I have been using the R2 increasingly as it has become more stable. In the process, I often find myself using the remote upon entering my home to activate a Home Assistant script to toggle a light scene. In similar situations, I might just want to turn a single light off or on without encountering a pop-up first that displays the full functionality.
I would like to submit a feature request to be able to decide, per button (entity), whether it should first open the pop-up with full light or script functionality or just make it one large clickable button, eliminating the need to press the small icon or to first open the pop-up.
Looking forward to seeing if others are interested in this, as I haven’t been able to find anything similar in the community yet.
I’m not sure I fully get what you are after, but I have buttons in R2 to activate a script in HA. As an example I have one for “Movie Lights”, another for “Tv LIghts”, one for “Go to sleep” etc etc. Works like a charm.
Sorry for the delayed reply.
What I am after is right now when I add a script to a page, then I can activate that script directly by clicking on the icon. However when I click on the name of the script, it opens a “more-info” page, with a larger button to activate the script.
Is it possible to configure the remote that when I click on the name of the script it also toggles the script instead of showing the more-info page? :slight_smile:
No, but you could also use the physical enter button on the remote to start the script if it’s selected. With a long press you open the details page. You can also invert this behaviour on the remote under Settings/User interface/Inverted button behaviour
Got it!
Thanks for the info!
