Fosi Audio ZD3 DAC - IR Codes
Does anyone have working IR codes for the “Fosi Audio ZD3 DAC”? Unfortunately, the codes I have learned, or uploaded via csv do not work.
I created a bug report: Unable to use new created custom IR-Remote - unable to send any IR codes · Issue #703 · unfoldedcircle/feature-and-bug-tracker
The error message seems to suggest that no output device is defined in the IR entity. Have you checkend that in the settings.
You’re right, the output wasn’t configured. Now the commands are working too. Thank you very much for the tip.
However, the second problem still exists—the remote control user interface cannot be customized—the page freezes.
This works with the R2 with 2.6.12
Strange. Have you tried different browsers and/or cleared the browser cache? And is the remote in the dock while using the web configurator?
I’ve tried everything, including private mode. I’ve tried it on a laptop, desktop PC, and iPad—the page freezes everywhere. Even with IR remotes that have been around for a while and editing has already worked.
Maybe ask over at the Discord channel where it is a bit more lively than here.
Fixed with 2.7.3
