Hi.
I don’t know if this is the place to make a suggestion - but if it is:
I would suggest adding the IR codes for the Formuler Z11 4K Android OTT media streamer. I have replaced my Zidoo (which you do support) for this relatively new and upcoming media streamer. I am not affiliated with Formuler in any way, but I am very impressed with this STB, and it is rated as a top contender for 4K media streaming STB’s.
I apologize If this is not the place to make suggestions - please let me know where.
it seams to be Android TV based. Why don´t you use the Android TV integration? On Android TV you must install the Remote Services if they are not yet running.
