Release 1.6.9 - 2024-02-06
Fixed
- Media player button mapping not working in an activity (#237).
- Media player progress time might go over boundaries.
- Entity state texts can be translated and are available on Crowdin (#290).
- Web-configurator:
- Home Assistant integration:
- Extract and convert color information from received HA light entities to follow external color changes. Supported color models: xy, hs, rgb (integration-home-assistant#7).
- Connection timeout setting was used as request timeout. TCP connection timeout was always set to 5 seconds (integration-home-assistant#47).
- Connection state handling in initial setup to avoid restart (integration-home-assistant#43).
Changed
- Info logs for button events
