marton
1
Release 1.6.4 - 2024-01-19
Added
- Activity groups: New option for switching activities: “Run modified off sequence” (#64).
- Run the original off-sequence of the old activity and dynamically filter out power-off commands.
- Web-configurator: configure, check and install Remote Two software updates (#274).
- Dynamic power toggle feature in remote-entity. Automatically add a POWER_TOGGLE command if the IR dataset has POWER_ON and POWER_OFF commands.
Fixed
- Web-configurator:
- Show correct dock status LED brightness value (#178).
- Available entities not shown in last setup-flow step.
- Backup: Show status display for backup and restore operations.
- Integration drivers: subscribe_events message sequence order after authentication (#272).
- Entity group toggle only toggles the first entity in the group (#279).
- Activity group shows the set default options for “Remove delays after turn-on commands” and “turn-off unused entities” instead of an empty setting.
- Web-configurator dock handling:
- Show correct version number after firmware update (#179).
- Improved error handling if firmware update failed (#54, #184).
- Show dock release notes if a new update is available.
- Clicking on the available dock firmware update notification opens the dock information and doesn’t automatically trigger the update anymore.
- Activity states are lost when editing an activity group (#225).
Update cookies preferences
