marton
1
Release 1.6.0 - 2024-01-09
Breaking changes
- Changed IR code format for toggle & sequence codes. This should not affect many users, since this was a hidden feature only mentioned in the API.
- The | separator is now used for two PRONTO toggle codes.
- The + separator is used for IR sequences of 2 or more codes.
- Manually added IR code sequences must be changed to use the + separator.
Added
- Additional infrared codesets for set-top boxes and generic TV codesets for: Mitsubishi, Panasonic, Philips, Sharp
- Settings option to always show battery percentage on the remote.
- Android TV integration: more app mappings, launch Max, Spotify, Steam Link, Videoland, Ziggo (thanks to Lars-’ contribution).
Fixed
- Sporadic system crashes related to key presses.
- IR toggle-bit support logic for RC-5, RC-6, RC-MM 32bit (Nokia32) protocols (#126, #129, #148, #234).
- Allow saving of activities and macros containing deleted entities (#208).
- Clear activity cache when editing activity group (#225).
- UI fixes and improvements:
- Unresponsive buttons after closing an activity.
- Inconsistent behaviour for unavailable entity for key select vs tap.
- Command execution loop when command fails.
- Wait for previous command ACK before sending new command.
- Language text retrieval.
- Web-configurator fixes and improvements:
- Resource upload: invalid image freezes & crashes web app (#232).
- Scrolling through available entities list resets to top (#242).
- Disable entity configuration if integration is disconnected.
- Confirmation dialogs for resetting button- and UI-mappings.
- Roon integration: disable album art image logging to prevent blocking, improved zone subscription logic.
- Home Assistant integration: reconnect to HA server after changing driver configuration, improved reconnection logic (#243).
Changed
- Home-Assistant integration: unlimited reconnection attempts by default (#263).
- Enhanced logging of activity groups and IR toggle-bits.
- Linux kernel update and keypad driver.
Update cookies preferences
