marton
1
Release 1.4.8
Added
- Android TV & Denon AVR: manual setup by IP address.
Fixed
- Roon integration: common improvements.
Release 1.4.7
Added
- Home Assistant scenes support. Active scenes with the push button entity.
Fixed
- Roon integration crashes (#109).
- Home Assistant & Denon AVR media-player sound mode selection (#165).
- Android TV crash after wakeup if a rediscovery is started for a non-reachable device.
Changed
- Disable fallback DNS, only use DNS set by DHCP.
Release 1.4.6
Added
- Denon AVR integration for network capable receivers.
- Multiple zones are not yet supported.
- Multiple ressource-file upload in web-configurator.
- Android TV: support rewind, fast-forward, menu and color buttons (device-dependent).
Fixed
- Dock firmware update for manually configured docks (#184).
- Android TV: improved reconnection handling and setup flow. Detect changed IP address.
- Philips Hue: runtime crashes if bridge communication failed or timed out (#150).
marton
Closed
2
Update cookies preferences
