Philips Hue integration needs to be reconfigured (delete integration and add it again).
Activities & macros: commands with parameters (e.g. light brightness) may need to be reconfigured (change parameter value, or remove and add command again).
Added
Roku integration.
Trigger Home Assistant scripts with button entities.
Download enhanced system logs with new “All services” option.
Pages in the UI will loop to the first page when reaching the last.
Load and display existing IR code when editing custom codes in web-configurator.
Fixed
Button entities will now show up in the activity & macro command list and are working in the activity button mappings & UI elements.
Note: already configured buttons in an activity might have to be reconfigured.
Commands with parameters (e.g. set brightness) work correctly in activities and macros.
Set default IR output in a new remote entity, if a single dock is available.
If multiple docks are available, no default output is set.
Philips Hue integration connectivity issues.
Download Roon integration logs.
Roon integration might not find outputs.
Commands might fail without error in the Apple TV integration.
UI displaying wrong country names.
UI commands repeated on bad request.
Changed
Using native keypad driver to fix stuck key issue. Note: we have seen sporadic system freezes with this driver and are investigating it! Please report if you experience button issues.
WebSocket reconnect handling: retry multiple times with old resolved IP address after disconnect or system resume.
Linux kernel update
Updated Bang and Olufsen integration dependencies.
