I just updated my remote to f/w 2.9.6 but forgot to look at the release notes before I updated it. Does anyone know what the release covered?
You can find it here: Discord
Or here if they not beta anymore (you still need to enable the beta checkbox to see it): Unfolded Circle
Also the notes are on the remote in the update settings.
But not if you already updated like the op
Beta Release 2.9.6
This patch update improves the Remote 3 display driver, adds an “Off” option to the Hue scene selection, and fixes Hue hub authentication with Remote Two.
Updated components:
- Android TV 0.9.0
- Apple TV 0.23.0
- Denon/Marantz AVR 0.17.0
- Global Cache 0.1.2
- Philips Hue 0.4.1
- Roon 0.6.1
Fixed
- Denon/Marantz AVR: mute and power state handling. Contributed by @henrikwidlund (denonavr#209, denonavr#210).
- Philips Hue: hub authentication with Remote Two (#787).
Added
- Philips Hue: added an “Off” option to the scene selection. Contributed by @stakats (hue#150).
Changed
- Improved the Remote 3 display driver (#561).
- Android TV, Apple TV, Denon AVR, Global Cache, Philips Hue, Roon: updated dependencies.
Known Issues
- Some Remote 3 devices are affected by ghost touches after wakeup. This is a different issue than the display artifacts. If you experience constant ghost touches, please contact support.
- WPA3 Wi-Fi security mode is not yet supported.
- Automatic display brightness and button backlight settings are not yet working in the UI. They are currently disabled in the web-configurator.
- Remote 3: the ambient light sensor sensitivity will be increased with a firmware update.
- Sonos integration: a recent speaker firmware update affects local device API access. Power-cycling the Sonos device may temporarily resolve connection issues. We are planning to rewrite the Sonos integration using a different API.
