I have a harmony elite but they no longer support it and its getting quite old obviously. I picked up a circle 3 as a down the line replacement. Setting up the harmony was easy, add the components. then set up an activity. I just need this remote to do those things. I have it on wifi but am perfectly happy with IR control. it saw my denon receiver and put 34 different integrations on the mainpage, and roku. I was able to add the samsung TV. I can see these on the web configure, but only see the denon stuff on the remote. I just want to have the samsung TV, dish hopper, roku, and denon receiver on the remote. Then I need to have activites setup to watch tv, play ps5, play xbox, etc. With the harmony i just made watch tv an activity, then said tv on, receiver on, tv output HDMI X, etc and it would start the activity. I can’t even get all the things on the remote let alone setting up a macro/actvity to change between things. Any good advice, particular places to start?
Logitech still supports the Elite. I just checked MyHarmony yesterday. Problem is nobody knows how long.
You already have entities (Harmony = devices) in your remote. 1st quick and simple solution is to go to customize your remote, create a page and add the important entities like Samsung and Roku to this page. Now you should see them on your remote.
Next step would be to create activities like the Harmony has which ist explained here a bit:
https://support.unfoldedcircle.com/hc/en-us/articles/13269248303516-How-to-create-an-activity
There are also some really nice videos on YouTube. A lot from Thrillcat
I’ll take a look at the video. There are things I can’t fine like the dish hopper. I need to fogire out how to get that stuff in too. I know the harmony is still supported. I’m still using it too, but its going to die at some point so this is the backup plan for that day. Thats why I’m not in a rush it get setup. Ive had it since the kickstarter shipped and just got it plugged in a month or 2 ago.
It took me a while to get the hang of how to set up this remote and find the right integrations, but it can learn IR codes from other remotes, so if you have devices for which there are no integrations, you can teach it from the original device remote.
