Hello everyone, I’m having some issues with my remote control.
Since the second-to-last firmware update, the screen of the remote briefly turns on every 2–3 minutes. Over time, this causes the battery to drain very quickly. I was hoping yesterday’s update would fix the problem, but unfortunately it’s still happening.
Another issue is that the actions only work intermittently. For example, I have set up “TV on” and “TV off”. This should turn on the projector and lower the screen via infrared, turn on the Denon receiver and Apple TV via Wi‑Fi, and switch off the Philips Hue lights.
Sometimes it works very well, but most of the time it doesn’t. I keep getting an error and not all actions are executed.
Occasionally I can fix the issue temporarily by restarting the remote.
I’ve already assigned static IP addresses to all devices involved in the network. That improved things a bit, but not enough.
Philips Hue causes the most problems. It almost never works.
Do you have any ideas?
And is it possible to trigger a Hue scene?
I need to control 5–10 lights. They are all controlled individually and end up at a very low brightness. So I would have to manually set brightness and color for each lamp. Running such an action would take forever.
And since Philips Hue is already causing issues, I don’t want to make things even more complicated.
Kind regards
