Error 404 - error while sending the command
I receive this command since a while. Rebooting the remote helps but it is super annoying. Does anybody have a similar issue?
Without logs it’s impossible to help you. Go to settings/development/logs and choose core service and the matching integration that is used when you get this error right after the error appeared. Use a site like pastebin.com to upload the logs.
Keep in mind that if you haven’t enabled prevent sleep in you activity the remote needs some time to reconnect all network devices after it wakes up from sleep. And if you haven’t enabled keep WiFi connected in standby in energy saving settings this takes even longer. On the remote itself under settings you can also enable an option to retry sending a failed command for a specific time. Unfortunately this doesn’t work for activity on/off sequences yet.
I had a similar problem with 404: the reason was a deleted macro as part of a sequence.
No macro involved. Sometimes it runs sometimes not. Very dissatisfied from the remote. Hardware top software not.
Reminds me of the Popcorn hour a400
Again, without logs no one can help you.
