I’ve been using the HUE integration and found out that the Toggle function for the lights is not Toggling to the OFF state in only switches on my lights ![]()
Hi, I can´t even get my integration to install. I get the message “Oops something went wrong”. Error Code “Other”. Someone else has this problem?
Hue integration was so buggy that I disabled it. Only using Home Assitant for now (my Hue lights are available via Home Assistant too)
Sadly have to concur, been trying to make a simple macro that switches 21 hue lights to state; OFF. And making the macro isn’t difficult but sadly each time I try to use the macro it already get’s off the rails with the first light which gives a time-out, will it is switched; ON. Per light it most of the time works to control it but I also find it very buggy and slow.
@Laess3r @jeroen Could you please send your logs with your Hue software version and what devices you try to control to support@unfoldedcircle.com? We’ll look into this.
You can get the logs from the Web configurator in Settings/Logs. Please choose the Philips Hue integration. Thanks
same here, will try it tonite again
Is there a way to use two Hue bridges? When I try to use the Hue integration for the second one, R2 tells me it´s already setup. As is I can control half of my house. Close to 100 Hue devices.
I have the same problem, and can’t figure out what to do with it…
According to this FAQ that’s not currently possible without a third party like Home Assistant.
Ok, I see.
Thank you anyway.
