Hello everyone, i am releasing my latest integration - Emby Media Player Support
This integration will give you a Media Player entity for all discoverable Emby Players with basic controls support.
During setup you will be required to put the IP:Port and API Key from your Emby Server, add the wanted players and that’s it.
I have tested against Emby Chrome Browser and Emby Windows App and verified functionality.
More in the README.md File.
i installed your integration, set up well (API KEY, URL server), i turn on my client Emby on LG TV SET but only 5 entities and all are unavailable!
I don’t have any session media player activities.
something wrong today. I reuse the remote tonight on same client device (TV LG) and no command works: Ressource not found!
I had to start a config again to update the device and the ressource has been found and commands worked well after that.
