Docks won't take IR commands
I’m trying to learn some IR commands and both of my docks are saying “This device does not support IR learning”. I’ve learned many codes before so I have no idea what happened. Does anyone have any idea?
Have you selected a dock which should learn?
Post picture of the configurator when you start to learn.
I ended up deleted and reinstalling the docks and that seems to have fixed the issue
