Allow disabling the status LED with a brightness value set to 0, except for OTA update, identify, and factory reset indications (#51).
Bug Fixes
Disable ethernet LED if there’s no link (#36).
With a link and the LED brightness set to 0, the LED will be switched off 3 seconds after receiving an IP address.
Improved OTA update error handling for invalid, aborted or dropped uploads.
